Datum Modifier Effects - Planar Surface 1
Viper555
Aerospace
I have been studying for the GDT Senior level exam (2009) and I'm really struggling to wrap my head around a concept laid out and exemplified in Fig 4-31 through Fig 4-33 (equivalent is Fig 7-34 through Fig 7-37 in 2018 (Reaffirmed 2024)).
The first example, Fig 4-31/Fig 7-34 makes sense because RMB is supposed to represent the feature datum simulator expanding until contact is made to the datum feature, thus constraining the part in rotation.
The second example, Fig 4-32/Fig 7-35, sort of makes sense because the BSC feature requires that it be in contact (similar to that of RMB), thus constraining the part in rotation.
The third example, Fig 4-33/Fig 7-36 starts to really lose me because it's defining the datum feature simulator at MMB, yet it states in Fig 4-33 that is must be in contact with one point. It seems that Fig 7-36 refines this illustration a little along with Fig 7-35, but it still doesn't address my misunderstanding and in fact further confuses me by placing part of the datum feature outside of the LMB/MMB established by the profile tolerance.
Here are my main questions:
1. In Fig 4-32/Fig 7-35, is my understanding of the BSC usage correct in that a datum at BSC requires contact, by definition, to the datum feature?
2. In Fig 4-33/Fig 7-36, why couldn't the part rotate CCW, provided the datum feature falls within the profile tolerance LMB and MMB?
3. In Fig 7-37 (there is no equivalent for LMB in the 2008 standard), why is the part profile able to pass when outside of the LMB and MMB limits?
Any help with clarifying this would be greatly appreciated!
Hi.... First of all, I think you're referring to just Fig. 4-31 and its sub-figures of 4-31(a), 4-31(b), and 4-31(c). They're all on page 73 of that 2009 edition.
Regarding your main question, in that third example where they invoke MMB, yes one point of contact (minimum) is required. The key is that the simulator is built to match the MMB of the surface, which includes the profile tolerance. In all three examples, the part is first contacted with the simulator for datum A (a collapsing diameter) and then rotated clockwise until it makes that one point of contact on B.
I'm not sure what you're asking in question 3, though.
Thank you
Thank you for the assistance and yes I meant Fig 4-31 (a), (b), and (c). Not separate figures like in the 2018 revision.
I'll try to clarify my question 3. Suppose that Datum Feature B comes in with perfect form and orientation at 4.9 in both illustration (b) and (c). What requires the part to make contact with the feature simulator in both of these cases once established on Datum A?
Aren't you left with a .1 gap in (b) and a .2 gap in (c) through which the part can (but not necessarily has to) rotate in order to meet all requirements simultaneously?
It seems to me that illustration (b) and (c) would still permit a datum shift equal to the difference of produced Datum Feature B and Datum Simulator B.
The previous Fig 4-30 even shows that there is rotation permitted at MMB. It would be like in that figure, the part could be produced perfectly at 14.9 and it would have a gap of .2 through which the part could rotate as indicated in the caption. I don't see the difference.
Considering that Garland's assumption about the figure numbers is correct, I would add the following:
4.31 (b) and (c) work essentially the same way, except the fixed location of datum feature B simulator from datum axis A is at 5 mm (basic) for case (b) whereas it is 5.1 mm for case (c).
In both cases contact between datum feature simulator B and datum feature B is required on at least one point. It is very likely to be just one point of contact in case (c) (MMB).
4.31 (a) is different because the datum feature simulator for B is not stationary. It is allowed some movement to make "maximum contact" with datum feature B. The contact is likely to be at 2 points or even more. Consider that the datum feature simulator is moved from the basic 5 mm location towards datum feature B and doesn't stop at the intial contact, but rotates the part a bit to make more than one point of conract (it is OK as long as it doesn't pass the LMB boundary located at 4.9 mm).
"...In both cases contact between datum feature simulator B and datum feature B is required on at least one point..."
This is at the heart of what I don't understand.
In reference to Fig 4-29(b), the last sentence of 4.16.2 states "Datum Feature B may rotate within the confines created by its departure from MMB and might not remain in contact with the datum feature simulator."
The same verbiage is stated as the last sentence of Section 4.16.4 when referencing Fig 4-30(b).
What is the distinction between the ability to rotate or shift the part in either Fig 4-29(b) or Fig 4-30(b) and Fig 4-31(c)? All of them are using the MMB condition modifier.
Even the equivalent figure in the 2018 revision, Fig 7-36, shows it as not having to make contact.
For 2018 Figure 7-37, when evaluating the profile on datum feature B, the part would not be oriented with respect to the LMB & MMB as it shown in the "Means this", it would be rotated CCW, as needed to satisfy the profile tolerance (which references only A), then the separate & independent process of establishment of the datum reference A, B would be as shown in the "Means this". Since the purpose of LMB is to ensure material is present, such as for a subsequent machining of datum feature B, all seems to be OK, I believe.
2018 Figure 7-36 though, I think is an odd one. Since MMB does not make sense for a planar primary datum feature, or for any primary datum feature that is not sufficiently closed to be constrained by the simulator/TGC, then why does Figure 7-36 make sense? I think it does not, so unless somebody points out something I may be missing, I will be working towards the next revision of Y14.5 having an explicitly stated restriction on the application of MMB to features that are sufficiently closed to be constrained by the TGC or location constrained to the higher precedent datum reference frame and also overlapping the origin of the higher precedent DRF (so not an offset datum feature such as datum feature B in these figures). In other words, when MMB is applied, it should only be for cases in which the potential shift of the part relative to the the DRF must be physically limited by either the datum feature being sufficiently closed or, for lower precedence datum features, by a physical constraint between the datum feature and its TGC.
As Burunduk said, the difference between BSC and MMB in Y14.5-2009 was just a matter of where the fixed TGC/simulator is located. In 2018 the intent was to allow datum referance frame shift for situations like the one shown in Fig 7-36, but the MMB case does not make any functional sense, I believe. The application of LMB to a case for which the TGC "does not fully constrain or limit the datum feature" still makes some sense, since it is still ensuring material is present. That said, I think we would be better off to just say that the LMB must remain inside or on (at a low point) the material. I see no reason to require that an extremity of the datum feature remain between MMB and LMB (as stated in 2018, 7.11.11 and 7.16.7).
P.S. - Burunduk - I sent you a message within the Eng-Tips site yesterday. Letting you know about it this way, since I don't know whether or not you will receive a notification.
Wow! Thanks! I think it makes sense now. The conflicting illustrations between the revisions (and the bit talking about the extremeties was throwing me off).
Just to make sure...you are saying that no matter what the scenario is, the entirety of Datum Feature B still must fall within the profile tolerance of 0.2 and you ARE able to rotate when a modifier is present whether it be BSC, LMB, or MMB since the rotation is only controlled by Datum Axis A in this case (RMB would lock it in).
CW rotation locks it at the high points (MMB and BSC)
CCW locks it at the low points (LMB)
If you make the part beyond the limits of MMB, you could even shave off some of the material such that it now fits in the profile and whatever other requirements are imposed could possibly be satisfied.
Did I say that right?
In 2025, the exam is for 2009?
Anyway, not that there are common examples of practical or actual uses of this series of "for completeness" tertiary datum solutions**, the most that can be said of Fig. 7-36 is that the theoretical allowance is for a tangential extended plane that is farther or nearer to the axis of rotation without the planar feature allowing a normal projection of the axis onto it. The greater the distance from axis to tangential extended plane the greater the amount of material in the part.
A different example would be that the plane used as a secondary would be a small flat on the bottom of a round feature, allowing a direct normal projection of the axis on it, which would clearly play havoc with all these interpretations, rather than the example planar segments that are in the Goldilocks zone of not being too close or too far. The examples are also ignoring that rotation of the part to meet the datum reference frame is going to cause interference with the vertical face, meaning a practical datum feature simulator/TGC has to also have a translation capacity in the non-LMB cases.
The practical item would be what the mating part would likely have also to do. This could be avoided by a notch into the horizontal surface that allows that rotation without interference, but one would know to do that if there had been a practical example to drive this set of rules.
**Funny name for a secondary datum reference, but the first reference constrains 4 necessary degrees of freedom, leaving only one to consider. Axial displacement is left free, but plays no possible part in these examples. In any case, the problem is what to do when an additional restraint is required that would otherwise conflict with a higher precedence restraint. The normal tertiary problem involves a face that is parallel to the example viewpoint as the primary, the OD as secondary, and the small flat as tertiary.
Hi Dean,
If you don't see a problem with referencing B at [BSC] in fig. 7-35, then I'm not sure why there should be a problem with referencing it at MMB in fig. 7-36.
In my opinion, what needs to change is the idea that when a datum feature is referenced at MMB, there should ALWAYS be a room for datum feature shift/play/displacement. Correct me if I'm wrong, as I wasn't involved in the release of the 2018 version, but I believe this exact idea prompted them to change the rule regarding the behavior of the secondary datum feature in Fig. 7-36 compared to Fig. 4-31(c) in the 2009 version. In my view, this change was unfortunate as it introduced an artificial requirement that makes very little functional sense.
Hi Dean,
I think there's a difference because in 7-35 there's a contact requirement similar how it was in the equivalent BSC example in the 09' version. As described in 7.16.6. In contrast, In figure 7-36 there's that artificial non-functional change you mentioned, not requiring contact, allowing "shift" but with at least one point of the datum feature staying between the LMB and MMB boundaries.
But the difference is because of the artificial requirement.
So, instead of proposing the prohibition of MMB application in such cases, maybe the artificial requirement should be removed?
How would one enforce this at the assembly station? Unless all these requirements are copied and pasted for all the related parts onto the assembly drawing, the assembler and the person creating the assembly instructions will have no basis to follow. I am unsure it is possible to build a gauge to accept compliant parts, that this is purely a CMM, let's toss this into the standard for no applicable reason, argument.
Thinking a second more - the reason this must be here is that they cannot generate new books, new training, new tests, and new courses if there isn't something incompatible with the previous version of the standard. Previous changes have been to which material condition is the default if no material condition is mentioned, whether symmetry and concentricity are allowed characteristics, and how datum features are symbolized on the drawing.
It is exhausting to have this non-standard flip-flopping standard. Any bets on what new incompatibilities the 2028 version, which should already be in public review, will have?
pmarc,
Then how, in your opinion, the cases should in figures 7-35 (BSC) and 7-36 (MMB) would look like?
In some training materials (for 2009) I've seen this case called "Offset Planar Feature MMB"
The specification for the two small holes is changed from A|B[BSC] to A|B-at-MMB. The physical datum feature simulator for datum feature B is now Fixed at the maximum material boundary for datum feature B. The datum feature is not allowed to translate or rotate and must maintain contact. (No Shift) But this time the feature is rotated to the simulator surface located at the MMB rather than a surface at the basic location.
So it is very clear stating (no shift) even the MMB is present in the FCF.
Notice that no datum feature shift is allowed in this scenario even though datum feature B was referenced at MMB. In other MMB (and LMB) specifications, datum feature shift is allowed to the extent that the feature departs from its MMB (or LMB). This effect is only applicable to scenarios of offset surfaces rather than the opposed surfaces in the previous examples of MMB modifier applications. There was no provision for referencing a surface feature (i.e. a feature that is not a feature of size) with an MMB or LMB specification in the 1994 or prior versions of the standard, so the 2009 version is providing additional tools.
So again, I am asking YOU, how would you "solve" this inconsistency?
Instead of asking for some alternative interpretation to what the ASME Y14.5 Committee has said is the interpretation to have, it would be better to find a situation you think your case would apply to. There are millions of mechanisms and assemblies in the world, surely one would demonstrate the concern and then the question is, what would be the appropriate way of expressing the requirement.
The example you give can be done without the "MMB" involvement by simply making the profile of surface tolerance one that is unilateral inside for datum feature B. This would put the nominal surface at the maximum material condition of the feature.
pmarc,
greeinimi,
I believe I've already answered the question in my last reply to Burunduk.
greeinimi,
So if the artificial requirement is removed then on the offset planar feature MMB there will be lo longer a requirement to touch the datum feature, right? Hence why "B" it is a datum feature in the first place, if no contact, or no arresting degrees of freedom occurs ? You can spin it around A (primary A) without be restricted by anything.
I am sure I am missing something.................
If the artificial requirement is removed, there will have to be a contact between datum feature B and its simulator. So this will basically be return to what the 2009 version defined.
But this would require accepting the fact that in certain cases of referencing datum feature at MMB (or LMB), datum feature shift may never be available.
pmarc,
Yes, I understand.
But then IF the datum feature shift may not be available (because supposed to be contact between datum feature B and its physical datum feature simulator) then why we are calling out B at MMB or B at LMB in the first place? Is this a chicken and the egg situation?
So how we can solve the conundrum? And where this issue was originated from? Why we ended up here ?
Deeper I go more questions I have.
Therefore, how to solve it ? Should RMB be the only viable solution for the offset unopposed plane surface, secondary datum feature? What do you think?
greenimi,
I think that per pmarc's position (which I agree with), in case of a return to the 2009 rules you would still be calling it out at MMB (or LMB) to indicate that the datum feature simulator is fixed where the Maximum (or Least) Material Boundary of the datum feature is. The actual datum feature would need to be brought to contact with it and stay like that.
Then how people did it pre-2009 standard? I guess instead of clarifying and be crystal clear and (there were no need to change it again in 2018) they did a half-ass job back in 09.
Now we are left to pick up the pieces and no idea how to fix it.
