TEMA DEU/CEU Heat Exchanger - Connection Challenges & Analysis 2
MchA
IT
Hello Everyone,
I am currently designing a TEMA type DEU (or CEU) Heat Exchanger and am encountering some challenges, particularly regarding the simulation of the shell-to-tubesheet connection.
Below are the key design conditions for the heat exchanger:
  • Design Code: ASME VIII-1 Ed. 2023
  • Design Pressure SS / TS: 85.5 barg + FV / 125 barg + FV
  • Design Temperature SS / TS: 190 °C / 390 °C
Materials:
  • Shell Course: ASME SA-516 Gr.70 + WO SA-240 321
  • Shell Girth Flanges: ASME SA-765 Gr.2 + WO SS 347
  • Channel + Tubesheet:
    • Option 1: ASME SA-765 Gr.2 + WO 347
    • Option 2: ASME SA-182 F321
  • Exchanger Tubes: SAF 625 (Strength expanded and strength welded)
I have the following concerns and questions, and I would greatly appreciate your insights and, if possible, any direct experience you might have:
  • Tubesheet Bolts: The original drawing specifies 2 3/8" bolts, a size not typically found in the TEMA standard. Is this size characteristic for such applications, despite not being under the TEMA standard?
  • Shell Girth Flange to Tubesheet Connection (DEU Type): The connection uses captive bolts within the tubesheet. However, for a DEU type, the channel typically does not feature an extended tubesheet configuration where the channel's outer diameter is smaller than the tubesheet's. Could this pose a simulation challenge? I'm finding it difficult to accurately model the tubesheet and the interface between its outer portion and the shell girth flange. Do you have any experience with this kind of TEMA Type? Does this configuration meet the DEU type definition?
  • CEU Type Design (Extended Tubesheet): If I consider a TEMA CEU type design, I can have an an extended tubesheet (configuration e, ASME VIII-2), but typically with through-bolts (not captive). The code provides calculations only for the extended portion. I suspect this simulation might not be fully realistic. Perhaps it would be more accurate to treat the extended portion of the tubesheet as an "integral flange" (even if this is a somewhat forced interpretation). Do you have experience with this type of heat exchanger? Would through-bolts be preferable to captive bolts in this scenario? How might I best consider this kind of connection and interaction in the analysis?
  • Temperature Difference & Material Compatibility: I am significantly concerned about the large temperature difference between the shell side (190 °C) and the tube side (390 °C). Furthermore, in the second channel configuration (with SA-182 F321 Integral as tubesheet/channel material), there is also a notable difference in materials between major components (e.g., carbon steel shell vs. stainless steel channel/tubesheet/tubes). How do these factors impact thermal stresses and potential issues like differential expansion? What design considerations or mitigation strategies should be prioritized here?
  • Nozzle Self-Reinforcement: In several high-pressure designs (like this one), nozzles are made with butt-welded self-reinforcement. Is this a mandatory requirement or merely a common practice driven by experience and conservative design principles? Do you have any advice on this?
  • Diaphragm Gasket: Is there any way to avoid the use of a diaphragm gasket in this specific design, and if so, what are the potential implications or alternative solutions?
  • Design Improvement: Lastly, are there any ways to improve this heat exchanger design, perhaps in terms of efficiency or cost, given the current specifications?
Thank you in advance for your attention and for any suggestions or shared experiences.
I stopped reading after the materials list, thermal expansion is a big deal.
From RT to 390C, let's assume an 8m long unit. the expansion would be:
Shell - 39mm
overlay - 56mm
Tubes - 46mm
As for construction I would recommend against using captive bolts is corrosive service.
Try considering NEU type heat exchanger since you're using corrosion resistant alloy in the tubes and weld overlay on the base metal anyway. That would address a lot of your design issues. Do you need mechanical cleaning for the shell side?
With that pressure as well, it would be difficult designing that captive bolts or girth flange. The bolting would also experience additional loading from the weight of the channel. You might need to add a saddle on the channel.
Hazop should have indicated that design T should be same on both sides. Design T should also state the range in temperatures from min design to max design for each side. Ask the plant operator what are the design cases for temp on both sides for diff thermal expansion consideration. Am not familiar with TEMA D head, have yet to see this being used in design or in a plant.
A materials selection engineer ought to chip in on possible galvanic corrosion concerns between tubes and tubesheet.
Sorry but I have to disagree with all of above responses. Differential thermal expansion isn't going to happen with modern clad plate so that's completely irrelevant. If the original exchanger was a TEMA CEU design you can't just arbitrarily convert it to an NEU as you would lose the ability to mechanically clean the shell side (very costly provisions were made to allow for bundle removal in the original design so it was likely done for a reason). And using different design temperatures for the shell side and tube side is quite typical and not a HAZOP issue.
-Christine
What about of PWHT?.
How did you plan to perform pressure test of shell side?.
It is advisable to convert the TEMA type to NEU, as designing a flange connection for CEU/DEU types can be challenging, especially considering the need for mechanical cleaning. The shell side fluid can be switched to the tube side, and there are contractors capable of performing mechanical cleaning inside U-tubes. If the service does not involve severe fouling, a fixed tubesheet design would be preferable. This avoids the complexities of CEU/DEU designs, such as increased bolting connection lengths, diaphragm gasket, and added loading to this connection due to the heavy channel.
Trestala said
".....a fixed tubesheet design would be preferable"
How did you plan to perform PWHT with fixed tubesheet?
Back to the OP, here are some potential issues i see with the original design:
1) The design pressures don't meet the 10/13 rule, so the shell side might not be adequately protected in the event of a tube rupture. Probably best to set the shell side design pressure to at least 77% of the tube side design pressure.
2) The internal pass partition assembly appears to be located on the inlet side but it should be placed on the outlet side. With the current location the tube-side pressure drop creates a differential pressure forcing the cover plate apart, potentially causing fluid to bypass the tube-side altogether.
3) Captured bolts can seize and become a maintenance nightmare but replacing them with a through-bolted design might not be practical. The channel to shell bolts could end up being so long that it becomes impossible to remove the top bolts without relocating the top channel nozzle further toward the channel cover (piping redesign).
4) Integrally reinforced nozzles are a good choice at pressures this high but it's rare to see butt-welded nozzles unless there is an API 934 requirement or other client requirement for using them. See if you can find out why butt-welded nozzles were originally used but you could reduce the cost significantly by replacing them with standard integrally reinforced nozzles.
5) 2 3/8" diameter bolts are not a standard size. They could require special tooling and could be difficult to source if they needed to be changed out.
At this pressure a solid 321 SS channel/tubesheet would be ridiculously expensive. At these pressures I've only seen weld overlay or clad used.
Also at this pressure and diameter I think a TEMA "C" channel is impractical. I'd consider using a Lummus Advanced Breech Lock (LABLEX) or some other proprietary closure design.
The difference between the shell side and tube side design temperatures is nothing that unusual. I don't see any implications.
-Christine
Tapped hole for stud: install the studs and avoid removing them.
A clarification: A diaphram closure does not typically use a gasket. The diaphram is seal welded to the channel flange. That is why the cover is beveled as shown. Partial bolting is installed. Weld as accessible, move the bolting, repeat till completed.
Mike
A diaphragm for Full Vacuum design ??
Is there some key concern with tubeside to shellside leakage past tube to tube sheet joints in this case:
"Exchanger Tubes: SAF 625 (Strength expanded and strength welded)"
If it helps, at a considerable cost adder, use a double tubesheet.
Thank you all for your valuable replies and insights.
FV both on shell side and tube side in the original project.
The redesign of the flange — now incorporating 2½" bolts — will increase both the flange thickness and outer diameter, which could lead to interference with the shell-side outlet nozzle. This is especially problematic given that the client has specified butt-welded nozzles, which require additional radial space for weld preparation, reinforcement, and inspection access.
That said, while captured bolts can be a maintenance challenge due to seizure or limited accessibility, I’ve noticed that most high-pressure heat exchangers I’ve encountered in practice still use captured bolts. The problem I’m facing now is that I’m calculating this exchanger as a TEMA Type C (CEU) for the connection shell to tubesheet, and the standard formulas assume through-bolted connections — meaning captured bolts are not covered in the design-by-formula approach (ASME VIII-1 + TEMA).
I do understand that an FEA will ultimately be necessary to validate the full mechanical behavior of this heat exchanger due to the non-standard bolting and geometry. However, I still want to push the DBF approach as far as possible — to develop a solid baseline and potentially optimize the layout before moving on to simulation.
The original project had SA-240 410S cladding on the shell side, but it has since been changed to SA-240 321, as requested. On the tube side, the channel was made by forging in SA-182 F321.This change in cladding material alters the thermal expansion behavior significantly. While 410S has a lower coefficient of expansion than carbon steel, 321 has a higher coefficient, meaning the cladding now expands more than the base material (SA-516 Gr.70).In many applications, this mismatch is minor or manageable. However, in this case — with temperatures up to 390 °C and high internal pressures (85.5 to 125 barg) — I’m concerned that the difference in thermal strain between the cladding and base metal might introduce additional stresses in the shell or at the flange-tubesheet interface.
Thanks for the suggestion. How would a double tubesheet work in this case?
1) TEMA is a standard, not a code.
2) The 2 3/8" stud bolt is included in ASME B1.1, no problem.
3) The stud bolt (blind threaded hole), or whatever you prefer to call it, is clearly defined in ASME VIII. Please read it.
4) Do you think diaphragm seal is suitable for FV design?
Thank you r6155 for your advising.
Regarding stud bolts in blind threaded holes, I understand ASME VIII clearly defines them, and Appendix 2 in VIII-1 provides calculation methods. However, my question is about their applicability to tubesheets under VIII-2. The software I use doesn’t consider the stud bolt connection explicitly; it only evaluates the extended portion of the tubesheet flange as per Figure 3.10 and the configuration in Figure 4.18.4(e).
From Interpretation VIII-1-83-176, Section VIII, Division 1 doesn’t include specific rules for tubesheets extended as bolting flanges, so U-2(g) rules apply. Also, VIII-2 does not explicitly link this configuration to Chapter 4.16 (bolted flanges) except for calculating the extended portion thickness. Moreover, Appendix 2 (VIII-1) says:
These rules are not to be used for the determination of the thickness of tubesheets integral with a bolting flange as illustrated in Figure UW-13.2, sketches (h) through (l) or Figure UW-13.3, sketch (c). Nonmandatory Appendix S provides discussion on Design Considerations for Bolted Flanged Connections.
Therefore, I assume it is not required to consider the stud bolt/tapped hole strength explicitly in the thickness calculation, and the evaluation of the extended portion alone is sufficient.
Please let me know if this understanding is correct or if there are further clarifications.
Regarding the diaphragm seal suitability for full vacuum (FV) design — that’s the original design, and I haven’t claimed it’s perfect (in fact, I see several issues with it). My question was precisely about how to improve it, and I want to thank you all for your valuable insights so far.
If tube side fluid leakage to shellside is a significant safety or production related concern, then a double tubesheet may be used. Here, the tube bundle goes through 2 tubesheets in series. The interspace between the 2 tubesheets is operated at a pressure less than the min normal operating pressure of the shellside in this case. So tubeside fluid would leak through a leaking tube to tubesheet joint into this interspace, and then get evacuated out to some disposal tank or vessel. Leakage of tubeside fluid into the shellside cannot occur so long as this interspace pressure is < min shellside operating pressure.
This equipment requires rigorous detailed manufacturing analysis by an experienced team.
Using the internet is not recommended at this time.
I have never used popular calculation programs; I use my own. Be careful.
Example: Avoid welding lifting lugs.
The blind threaded stud hole is essential for thick walls. The stud is shorter and only has one nut.
My experience: Reactor PV (nuclear): 76 M 220 studs, L = 2500 mm, 850 kg each.
