HUD Foundation Inspections 1
dowengr
Hello All,
I’ve been receiving frequent requests to provide HUD Certification Letters for manufactured home foundations. The initial projects were manageable, as clients provided drawings, specifications, and previously stamped engineering documents. I inspected the foundations and structures, verified no modifications had been made, and confirmed their good condition.
However, I’m facing a new challenge with a potential client. They lack drawings, specifications, or original build documents and have requested I complete the certification letter within a few days. Additionally, they proposed deferring payment until the house closes escrow, which I declined.
Does anyone have advice on how to approach this situation, particularly regarding the lack of documentation and tight timeline? Any insights or best practices would be greatly appreciated.
Leaning towards declining this project.
Don't you just check to see if it meets HUD guidelines? i.e. pier and strap spacing etc.
I get paid from escrow at closing frequently and it is never been an issue.
Can you clarify? If there's no drawings/specs to review are you physically visiting the site and climbing underneath the home to verify how the thing was installed?
I did a couple of these years ago and quickly decided that it wasn't worth the hassle, meaning that there wasn't enough money in the meager fees to cover the effort required, including crawling around underneath these things. I found that there was a good chance that the manufactured home foundation would probably not meet the HUD guidelines, often times not even close, meaning that a design plan for modifications would be needed, and I often felt that there was little chance that the required modifications would be realistically accomplished. So I chose not to get involved in these. I still occasionally get phone requests to inspect and certify these for HUD compliance. I decline.
FYI to the OP, last time I checked there were a few nation wide operators that compete in this space for a few hundred dollars per assignment, so that is what you are up against.
I have done one of these and decided it was not for me. But, yeah, go to the site, check pier spacing and straps and whatever else HUD guidelines there are.
I got some more information from the realtor today. Home was bought at an auction, fix and flip contractor polished it up and is now selling it. They don't have any documents or paper trail for the construction of the original home.
@JAE Yes, I would have to get under the house and crawl around, take measurements, verify the pads in the middle of the house, dig down to verify the footing thickness and depth, verify adequate ventilation, hold downs, anchor bolts ect... Still no way to verify the rebar or concrete strength without additional testing. After all of this, then go through the HUD documents and verify compliance. Seems like a lot of work, not to mention the crawlspace is probably super nasty.
Seems like the consensus is to turn down this work.
I did a few of these that were supposed to meet HUD's, "Permanent Foundations Guide for Manufactured Housing 1996 [PFGMH]". Absolutely #1, get paid in advance of even going out. I go out, they have drystack block and screw in soil anchors about 95% of the time, neither of which are allowed in the 1996 version. Then no one wants to pay since I will not OK it. I quit doing them altogether. I have even told owners on the phone, to go look under the house because they are both easily detected. If they are present, I can't help them.
Later someone else goes out, Oks it, get cheerfully paid and provides some documents that are accepted by whoever. I can't find one statement in their documentation that says the setup meets PFGMH. There is a lot of double talk and word salads, but nothing we would call definitive. Those people are the ones GTE is referring to. Basically, the bank or whoever is accepting non-committal garbage. What they are generally saying is that it meets the minimum requirements of the state mobile home commission and in most cases, they do. But that is not PFGMH requirements. State mobile home commission allows drystack block and soil anchors.
Some have mentioned a newer version of PFGMH that is more lenient, problem is, it was never adopted as of the last time I looked into it. Even the copy I was given said "Preliminary Draft". That was in about 2017. I also heard the new version was actually created by suppliers and presented to HUD to confirm, not that HUD authorized it. They do present it as if HUD created it.
Hello All,
I do these all the time. You don't need to overcomplicate it. You need to crawl underneath, and confirm the piers and strapping are in good shape, measure the abs foundation pads, measure pier distances at the I-beams, measure the transverse and longitudinal strapping distances, confirm strapping connections, evaluate top of anchors, if possible, see if Oliver-tech v-braces are installed. You gather your values and compare to the PFGMH manual. Either the values you measured will be passing or not, if not you tell them to correct from a qualified manufactured home installer.
I have not looked into the PFGMH requirements for about 8-10 years. Have they finally adopted a newer version than the 1996 one that more aligns with products on the market? It would be good if they have. The 1996 version had some outright restrictions such as "Screw-in soil anchors are not considered a permanent anchorage" that I could find no way around but felt soil anchors can work if designed and installed properly.
Also, I do not think the 1996 even mentions Oliver-Tech. I called Oliver years ago when I first encountered one with their system. They said they meet HUD but would never commit they met PFGMH 1996. I got a noncommittal "okey dokey". I also asked how their slide prevention system overcomes uplift. They answer was that stopping sliding means that uplift cannot happen. I disagreed.
This appears to be the active version: HUD PFGMH Looks like it's still from 1996 (revives and revises the 1989 version, references ASCE 7-92)
I've done one of these. I'll never do another. It was a hike - about 2 hours away (closest city with another Structural engineer in that direction is about 5 hours away, so we were the closest). Went out, looked at it - nice, pretty brick veneer skirt; dry stack blocks; straps that were loose and sagging. Went back to my office, wrote up the report saying it didn't meet the standards and roughly what needed to be done, and sent the letter. When the invoice went unpaid for 3 months, my boss called the realtor - she screamed at him for stopping the sale and ruining the owner's life (apparently that was their last chance to sell - it went into foreclosure shortly after the buyer backed out), and hung up.
As a rule, I'll never take a job that won't be paid until escrow closes. Too much of an appearance of a conflict of interest. I instantly have a vested interest in seeing that transaction through. Because if escrow doesn't close, it gets real hard to collect payment.
I do these from time to time. Most of the time they don't meet the requirements and I stand my ground about what needs fixing. If you are familiar enough with the guidelines, get paid in advance, and don't mind crawling around in a dirty space below the homes than it's fairly easy work.
Your experiences mirror mine. I insist on payment before I even go out since 95% of the time, it does not meet the requirements. No one is willing to do what is necessary to mee the code and therefore will not pay without a fight. They do meet the state mobile home commission requirements but not PFGMH.
I'm in Florida, so I also reference FAC 15C. Essentially the entire component (anchor, strapping, connections) needs to withstand a working load of 4,725 lbs. to be on the approved product list, so I use that as prescriptive design value, as that's what should have been initially permitted for. Regarding the screws, there's really no way of verifying without the original plans. For the V-braces, I will typically provide the spec sheet.
At my firm we have have the client pay upfront with a card or on site with a check. We go on site and crawl underneath to pull the necessary dimensions. We built an excel sheet to run the calcs to help us verify it is HUD compliant. You definitely dont need existing drawings but those always help. As to the is it worth it question I usually think it is, but I dont mind getting into crawlspaces with spiders, frogs and the occosional raccoon skeleton. Definitely not worth it after a solid rain and those crappy crawlspaces are flooded.
Interesting. I can count on one hand the number of times I have had an issue with that.
It's not so much because I've been burned, but the appearance of a conflict of interest. If me getting paid is somehow tied to the transaction going through, and my findings could potentially nix that transaction (and, by extension, me getting paid), I'm on shaky ethical ground and my findings should be considered questionable.
I'm sure there's ways to handle it, but I chose to take my business in a different direction rather than navigate that.
Just because you are told you will be paid at escrow does not mean you won't be paid if the deal blows up. Your customer is still on the hook to pay you. Happens to me regularly. My customer is generally the real estate agent and they end up paying me one way or another as they don't want to sour our relationship.
Just have them sign an agreement before hand.
Couldn't you just add some language like "invoice is due and payable regardless on the outcome of the escrow"? When I work through architects, I have a clause which reads "there are no paid when/if paid provisions in this agreement." Alternatively, if the escrow is to close in xx days (30, 90, whatever), you could put that provision in your agreement, something like "Invoice is due and payable at close of escrow or 90 days, whichever comes first."
Just my two cents.
