North Korean Ship Fails/Capsizes at Launch in Front of Kim 1
racookpe1978
Nuclear
Feb 1, 2007
5,991
Details from the available British Commercial Press are few, and what is published contradicts itself.
In a statement KCNA said: 'Due to immature command and operational negligence, the parallel movement of the bogies could not be guaranteed, resulting in the launching sled in the stern detaching first and causing the ship to capsize.
'The ship's balance was destroyed due to a rupture in the hull in some sections, and the bow section was unable to detach from the keel.'"
Basically, a North Korean frigate (about 5000 tons displacement) either capsized or rolled off of its forward launch platform when a "dolly" collapsed during the movement.
My assumption is that it was a sideways launch using two cradles, and the stern cradle released first. The bow was still fixed, and the hull torn apart as the ship twisted. The ship did not "capsize" in the water, but rolled over on the launch rails.
Several workers were killed, others injured. But, this is in North Korea. And, in North Korea in front of a public ceremony in front of their Leader. Many more will be killed in retribution for the insult to the Leader. And their families, their relatives of the workers, designers, engineers, and shipyard crew.
Strategically, obviously their Navy is hurt by the loss of a future ship, and the damage to the shipyard and its docks and launch gear. And, any losses to the North Korean arms build up helps the world. But, instead of a "lessons learned" improvement, they will lose dozens (hundreds ?) of irreplaceable launch crew and workers in punishments that will delay future construction for years.
That side slideway type of launching is one of the safest methods from a stability standpoint but it does rely on a crew to cut multiple restraining bars simultaneously during the launch. Transitioning from being supported from the bottom to supported by buoyancy can create some challenges. It's best to just huck it into the water sideways.
Stern launch ("Break the champagne bottle on the stem") creates the greatest stress on the hull girder as the stern begins to get bouyant, but the bow is only partially cradled by the forward half of the sliding ways. Launching is a tricky problem, aside from the "simple" weight and moment and center of gravity issues. (Which are not simple at all!)
That's why this incident, and the shipyard and navy people who will be murdered because of it, will be so destructive to the NK Navy construction. /and that is a good thing
Stern launch is also the most challenging in terms of stability because the narrow now is supported on centerline blocks and the only a fraction of the vessel is buoyant to provide righting moment.
Insane reaction by their government. "We goofed up. Hide the failure!"
What in all bloody Hades "good" do those hundreds of blue tarps do towards recovery of the ship, of allowing partial salvage of the internals or of cutting up and moving the remains to begin building a new hull?
Wait! I know!
The blue tarps were required by FEMA to keep the rain out!
Sorta reminiscent of a dog thinking he's hiding behind a tree.
Except the dog's kinda cute, doing it.
spsalso
The blue tarps prevent satellite or aerial photos showing more details of the damage, which might also provide insight into the details of the design and construction.
So, they're a perfectly logical reaction.
The structural member in all cases i am aware of that synchronizes the dolly or skid motion is the ship hull.
The launch systems I am aware of are all specific to individual shipyards (or possibly design agencies).
At the launch pivot point, the skid assembly can be subject to very high loading, and must protect the ship hull, Here is an example of a less than stellar method of handling the energy at the pivot point.
Jun 3, 2013, A video of a failed ship launch
Things that can cause one end of the ship to lead the other during a sideways launch include
  • Triggers not releasing together
  • Non uniform resistance in the launchway
  • Cradle or Dolly failure
Getting all of the launching tasks to work together requires considerable skill and coordination among the Launch Master and Crew. This is at the same time that management and the customer want to perform a launching ceremony with great pomp and circumstance.
This is how sideways launches go when the launching process is done correctly.
US Navy Launches New Warship Sideways Into Water — USS Billings Christening and Launch posted Jul 3, 2017, Marinette Marine shipyard , on Lake Michigan.​
I don't really see any failures in the launch of that NOAA launch other than the cameraman being in the wrong location.
As for the last one, the launch wasn't a failure, the whole project was.
I mean what synchronised the release of the Dollies? Is it electronic actuated? Guys with sledgehammers?
Guys with torches in the videos I've seen. We're doing some new construction right now. I've never been to a launch.
What ever launched the Billings looks like a real machine. Didn't see any guys with torches :)
No damage done, just execute a dozen or so bosses and workers and get on with building a new one and launch it in secret while pretending and informing everyone it never happened - "what failed launching?"
Clyde they used cutting torches and loads of swearing by ship wrights. There was a surprising amount of running out the way to ensure safety.
They had a suggestion to use copper wire cutting charges to cut and I believe now do.
