Temper Embrittlement(TE) 2.25 Cr 1 Mo steel P22/F22
deepu78
AU
We are modifying old existing 2.25 Cr 1 Mo A335 P22 (Desuperheater ) piping to incorporate a new type of desuperheater. The new piping material comply with Jfactor <100 requirement. We are not sure whether the old material complies.
My query is can we determine how much extend temper embrittlement(TE) exist in the old piping by
1. Chary impact test- in existing(old)- replaced piping during modification
2. Can we determine MPT(minimum pressurisation temperature) required to avoid TE which has undergone long term exposure in the range 345 deg C & 575 deg C
DV
I have reviewed similar 2 1/4 Cr 1 Mo piping installed in power plants from 1995 thru 2015 and don't recall a J factor callout for it. Maybe once after 2010.
I have not yet conducted such an evaluation. However, as outlined in the EPRI document "Embrittlement of Power Plant Steels" (publicly available on the EPRI website), you can estimate the FATT using predictive formulas based on the part’s chemical composition. Additionally, metallography and energy-dispersive X-ray spectroscopy (EDS) can be performed at high-risk locations to assess microstructural and compositional anomalies.
If these preliminary steps suggest potential embrittlement concerns, small punch testing may be employed to estimate material toughness. Where sufficient material is available, a series of Charpy impact tests could further validate the FATT determination.
https://www.epri.com/research/products/000000003002001474
Actually one of the main methods to determine the extent of temper embrittlement is to add a test block inside the equipment (for example reactor heads) then we take a piece from it and make an impact test and take the results from API 571 or API 934-A. Controlling J factor for base metals and X factor for weldaments are widely used and proven reliable.
