AVG and F symbol - fig 8-14/2018
greenimi
Figure 8-14 Specifying Restraint for Nonrigid Parts
Is F modifier in the circularity needed in figure 8-14?
I am asking this because in fig 8-13/2018 F symbol has been removed (relative to the equivalent figure 5-13 from 2009)
Why F was kept in 8-14?
As all ways I am scratching my head.
But my assumption is hollow or tube like parts are
Flimsy. And even thou are in size. Have to be
In the restrained condition. In the old days
A note was applied (inspected in the restrained condition) in the example above a fixture is required, mounted on A & B.
Thus intent it will assemble, runout acceptable.
Is this a correct assumption?
so I had this wrong the note on the fiquire contradicts the free state symbol.
I ask AI because it is smarter than I am
Overview
GD&T Tolerance Symbols | GD&T Surface Profile | Modifiers
In ASME GD&T, a circle enclosing the letter "F" signifies a "Free State" tolerance. This indicates that the feature's geometric tolerance is assessed in an unrestrained condition, without any applied force or load.
Elaboration:
  • The Free State symbol (F in a circle) is used in conjunction with a feature control frame to indicate that the geometric tolerance applies when the feature is not constrained or loaded.
  • This means the tolerance applies regardless of whether the part is deformed by external forces or by the way it's supported during manufacturing or assembly.
  • For example, if a hole is specified with a free state tolerance for perpendicularity, the tolerance would apply even if the hole deforms slightly due to a clamping force.
  • For example, if a hole is specified with a free state tolerance for perpendicularity, the tolerance would apply even if the hole deforms slightly due to a clamping force. "
This is wrong. If the tolerance is applied at free state, there must be no clamping forces or elastic deformation when the part is positioned for inspection. Be careful with AI.
Burunduk
I defer to you and accept your correction.
As the ASME Handbook gets more complicated.
Definitely we need to all calaborate. And brain storm these issues. I commend greenimi on this one. I guess this one really depends on what an engineer needs and the correct GD&T.
In my line of work hollow or solid shaft are inspected between centers. In some cases some type of arbor is used to restrain parts inside datums per drawing or as tooling.
Many form tolerances are used often.
Runout, perpendicular, parallel, total runout , roundness and cylindricity . And more.
Inspection in free state generally mentions
That part must be inspected with out restrained.
And restrained condition use to mean it can be fixtures in some manner. To me it's that simple.
With out physical actual training this us complex to train verbally or written. And takes years of experience.
I have agree with Dave. ASME is making it to complex and is stirring the pot , so to say.
mfgenggear,
At free state you may still need to support or hold the part in some manner, by devices used as datum simulators, but not only.
Datum simulators could be a granite slab, angle block, v-block, centers, etc. However, you don't clamp to them by force at free state. If the part deformed when you fixtured it for inspection, that is not a free state measurement. Free state is the default and as such it does not normally need any indication on the drawing, except for those cases in which a restrained condition is required by a drawing note. A restraint note such as shown at the bottom of the figure in OP's post overrides the free state default. But unlike that specific figure, often it applies UNLESS OTHERWISE SPECIFIED. Then the otherwise specified controls or datum references are the ones indicated by the free state symbol (circled F).
mfgenggear,
Yes I agree, but technically it's not restraing it's locating. But I am cutting hairs.
It's all good. The challenging parts are ring gears.
Keeping them round. In the unrestrained condition.
Sitting on a granite surface plate verifying flatness and roundness. I guess it what we think we are doing in our head.
