SAEEDGH
- May 11, 2024
- 30
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
for repairing and servicerotate for fabrication?
or it will it rotate in service ?
its not appropriate for this goal. i want to rotate abous green axis.A slewing ring bearing with a drive pinion comes to mind.
Electric rotary headView attachment 9083
hi.
i want to design a structure for rotate this part about green axis.
can you seggest me a mechanism.
dimention of part:
9906 mm
2658 mm
cross section: 450*450 mm
weight:9000kg
Let's try this again , let's establish axis., y, x , and z. Z would be direction of the axis. Axis w would be rotating of the entire part. Are want to rotate ot move in the z axis?View attachment 9083
hi.
dimention of part:
9906 mm
2658 mm
weight:9000kg
