Honda Recall - 3.5L main bearing problems
Well, Toyota is replacing 100,000 Tundra engines due to main bearing issues from manufcturing debris.
Per the infamously accurate New York Post, the current recall is an extension of this previous recall:
Honda (American Honda Motor Co.) is recalling certain 2015-2020 Acura TLX, 2016-2020 Acura MDX, 2016 and 2018-2019 Pilot,2017 and 2019 Ridgeline, and 2018-2019 Odyssey vehicles. Due to a manufacturing error, the connecting rod bearing in the engine may wear and seize, damaging the engine
. . . defective (convex/concave) grinding of the crank pins due to mis-setting of manufacturing CNC leading to main bearing failures. (or, QA not controlling for GIGO in the automation)
Engine bearings today are designed right on the edge of robustness to maximize performance. When you couple that with shortened development lead times, I'm not too surprised...
The post above yours described a manufacturing defect, not a design fault.
Yes... and the closer a design is to the edge of robustness, the more likely that a manufacturing variation/fault can create a problem.
In my opinion, the main problem for failures is cutting corners, the excuse I have read and heard is oil gallery debris. It seems those manufactures are too proud to ask for help from independent folks, like back in the 50's and 60's when the big 3 would call on people like Smokey Yunick, to help solve problems.
Low viscosity lube oil, what can happen with that?
Why do you doubt the bearing debris issue? Plenty of engines run a happy life on low viscosity oil.
Reality was the exact opposite. Like many of his peers, a major reason for Smokey's success was that he received a ton of OEM and Tier1 engineering support, both in terms of knowledge and hardware. Many of "his" innovations were actually poorly-camouflaged factory efforts like the three '67 "2/3 scale" Chevelles - the first two being GM Engineering built, wind-tunnel tested cars and the third being a Smokey-fabbed copy. An unfortunate reality of history is that folks receive too much credit as often as they do too little, which inevitably makes others (me) feel like a dick when they point out inaccuracies.
As for quality issues, they're inevitable.
Don't worry about it CW. Engrus is just still holding out hope that Mark Reuss is going to call him back and offer him a billion dollars to fix every single engineering issue that GM has ever had.
Everyone but him knows exactly how likely that is.
re durability - there's a guy who does engine teardowns on youtube - 'I do cars'. It is interesting to see that while most engines have failed due to neglect or abuse, how often the bores and bearings are in really good shape except for the items actually clobbered by the failure. A lot of the stuff he says is bad or gone, I would call 'a bit worn, but with a lot more life in it' So with modern lube and design and mfg and materials - motors tend to be really good.
A fellow on youtube did a Toyota tear down of one of the problem engines. There was no sign of a debris related problem. That is why I doubt it for one. And two, what are the odd's that unrelated manufactures are all claiming that exact same problem.
There is more than one thing that is the cause. Maybe my favorite follower here can point all those manufactures my way. ;)
I jump in late. It can be many many issues.
So since it's new engine issues.
I most likely is engineering and manufacturing .
Out of tolerance , crank or bearing.
Both could be supplier. Wild guess
If it's a problem affecting primarily Japanese manufacturers, there is a good chance that they have a common supplier.
I think the trouble on the American vehicles is that they're adopting European practices. These fail for entirely different reasons than quality control.
As is box stock behavior on this forum, certain people who are absolutely clueless are speculating wildly about how bad a problem is with no idea of the rate, which is by far the most important factor. So let's talk about rate.
For Honda - we're talking about a current known failure rate of around 1 in 8,500. Thats a failure percentage of around 0.0125%, or a sigma value of approximately 5.5.
For GM - current known failure rate around 1 in 22,500. Failure percentage of around 0.004%. That's a sigma value around 5.65.
Those sigma values are both below the lofty 6 sigma target that everyone aims for these days, but neither of them are particularly horrifying.
As usual, much ado about nothing; another case where someone sees an NHTSA investigation is happening and suddenly the world is over. Emergency calls to Smokey Yunich not required.
