PFA Liner detached from flange surface
For one of our projects, we have a PFA Lined piece of equipment. On inspection, we found out that the liner is detached from the face of the flange (about 2-3 mm). The supplier claims that this is normal practice and the gap will close once the piece is bolted to the pipe. I am sure that will be the case, but I believe there will some stress put into the liner during the bolting process.
Is there any acceptance criteria on this? I have checked F1545 but there is nothing on clearance between liner and housing metal (or flange face, where we are seeing this)
My experience with lined pipe and fittings is that the liner is in contact with the flange face.
any help will be greatly appreciated!
RE: PFA Liner detached from flange surface
That's normally not a good move as the lining can creep over time and result in flange leakage.
Linings around flanges are very problematic in terms of sealing as are linings .
How was this lined?
Any drawings, photos?
Yes, the liner extends to the flange face (standard practice in my experience)
The manufacturer also claims that the "detachment" is industry standard, in line with what CompositePro stated.
Thanks again guys, much appreciated!
To the main question, PTFE liners do not adhere to the piping itself, they are just molded to it. I suspect it would be similar for PFA. The only ones I would question that for would be any piping that is roto-lined. In those cases, the liner is supposed to adhere to the metal substrate.
