Draw columns in ETABS
Do you have nodes drawn already? Usually you need nodes to connect your frames to.
Also - check veiw settings to make sure something weird isn't happening like frames being turned off
I have the grid lines. How do I draw nodes, or assign nodes to intersection of grid lines? thank you.
Figured it out. Can't draw on ground level. Need to be on 1st floor.
Hm - weird.
Yes - gird line intersections work like nodes
