Minimum ground clearance required as per IEC for Transmission line
balaji.srinath
IN
Hi all,
In which IEC, it is mentioned the minimum ground clearance for different voltage transmission lines.
Balaji
Google say 60071
Did you even try to do some research?
@ balaji.srinath
Did you try IEC 61936-1 title Power installations exceeding 1kV AC and 1.5kV DC Pt 1.. See whether any data therein that your are looking for.
Che Kuan Yau (Singapore)
Hi littleinch & che12345
In both the IEC standards 60071 & 61936, Ground clearance w.r.t Transmission line is not mentioned..only phase-phase & phase-earth (conductor - conductor & rod - structure) is mentioned w.r.t BILs.
Balaji K
Clearance above ground seems to be a country by country thing based on historical clearance and country specific reasons.
Most trucks are max 5m, maybe 5.5 so add that to the phase to earth distance and add a bit for safety.
The "bit" probably varies between countries.
Hi Balaji,
to my knowledge, the only requirements regarding clearances are reported in the European Standard EN 50341-1.
In principle, the armonized standard requires basic clearances and reports the attendant formulae.
A "basic" height of 5 m is assumed for objects beneath OHLs in "normal" areas; electric (lightning or switching) clearances shall be added to the 5 m to obtain the clearances.
National annexes (EN 50341-2-XX) report specific values for each country.
Si duri puer ingeni videtur,
preconem facias vel architectum.
IEC 60919: “Overhead lines - Design criteria, construction and maintenance.”
