Hi, how can I generate event series
AMRITESH
Student
IN
Hi, how can I generate event series for ABAQUS AM plugin. I am trying by generated G-code from replicator software. But is it possible to define our own tool path in Replicator software and the creating event series from eventseries.py file.
Well, there are 3 options:
- use the predefined patterns from ReplicatorG
- modify the generateEventSeries.py script or write your own script more or less based on it to process g-codes from other software than ReplicatorG
- if you only need a simple path, consider generating it in Excel, SciLab or similar software
