DEBUG/EPRINT in ADAMS CAR
ichbinpulkit
Automotive
DE
Hello @GregLocock,
You once suggested me to go through the DEBUG/EPRINT. I did, Somehow I am unable to understand how to determine the problem. Should I understand something from the Jakobian Matrix or search the part through it's ADAMS ID and look for what could be wrong.
In this case there is a lot of iterations and also steps then... How can I determine the root of the problem. You can maybe check the .msg file I have attached.
Viele Grüße
Pulkit Sharma
 https://files.engineering.com/getfile.aspx?folder=e4d8d960-fae9-4fc3-9116-ab645f545f77&file=test_accel.msg
Could you elaborate it somewhat better and deeper?
Why is it not there in the ACAR Help/Guidelines?
Viele Grüße
Pulkit Sharma
Thee lines here tell you that the maneuver is over
The maneuver is finished.
command: !
command: stop
Termination status=0
Elapsed time (sec) during dynamic simulation spent in:
Predict Correct Jacobian Eval Solver(NF) Solver(FBS) User Subs Contact
________ ________ _____________ __________ ___________ _________ ________
1.90E-02 1.82E+02 2.33e+01 7.27e+00 2.71E+00 8.79E+00 0.00E+00
0% 99% 12% 3% 1% 4% 0%
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 186.31s, CPU time = 41.95s, Average CPU load = 22.52%
Cheers
Greg Locock
