Center of Pressure for a pressure distribution on a curved Surface
hey everyone, i have a structure that is having a complex curvature, the curvature has some varying pressure distribution and i want to find the center of pressure for this pressure distribution. how do i do that on FEMAP. FEMAP gives me loads and moment along a requested CSYS but it doesnt give Cp for the applied load. Any suggestions , ideas? Thank you in advance
RE: Center of Pressure for a pressure distribution on a curved Surface
run the shell model. to do so, you'll need 6 constraints to remove rigid body motion.
Otherwise, the NASTRAN F06 file includes a summation of the applied load, "OLOAD" I think.
but in FeMap, under Tools/Check there is "sum forces" which might do the same thing directly ?
or run in FeMap with one point constrained in 6 dof ... this'll give you the resultant about this point. if you're lucky (or clever) and the point is on the line of action, then the three moments will be zero.
