Wunderbear
I was working on a relatively simple injection molded cosmetic component and was searching for appropriate standards for specifying tolerances on molded parts so I can factor that into material selection. I found several standards such as: DIN 16901: and one from SPI: and fictiv:
I had it narrowed down to two materials: nylon 6,6 and polypropylene homopolymer (mostly based on chemical compatibility). I was inclined to pick polypropylene over nylon as it has much less moisture absorption and comparable shrinkage. However, I was then surprised to learn that polypropylene has much worse tolerances for both linear dimensions and flatness than nylon 6,6 in the standards I mentioned above. so the questions are:
a) Do the standards represent reality?
b) If so, what properties are behind the larger tolerances for polypropylene?
