Tolerance differences between polypropylene and nylon 6,6
Wunderbear
13
I was working on a relatively simple injection molded cosmetic component and was searching for appropriate standards for specifying tolerances on molded parts so I can factor that into material selection. I found several standards such as: DIN 16901: and one from SPI: and fictiv:
I had it narrowed down to two materials: nylon 6,6 and polypropylene homopolymer (mostly based on chemical compatibility). I was inclined to pick polypropylene over nylon as it has much less moisture absorption and comparable shrinkage. However, I was then surprised to learn that polypropylene has much worse tolerances for both linear dimensions and flatness than nylon 6,6 in the standards I mentioned above. so the questions are:
a) Do the standards represent reality?
b) If so, what properties are behind the larger tolerances for polypropylene?
a) probably, but I would talk to a molding shop about what might work and what might not.
b) Polypropylene is a non-crystalline material in as-molded form, vs. nylon 6,6 being more highly crystalline.
Polypropylene is a semi-crystalline material.
Tolerance tables look ok. Sort of generalised.
What is the variation in size which would be acceptable? (As a %age)
Have you checked the comparative material costs of your choices?
Nylon 12 has low water absorption and outstanding chemical resistance. It also has a low density for a nylon.
Politicians like to panic, they need activity. It is their substitute for achievement.
