Thread repair in studding outlet ASME BPVC VIII-1 1
FoxRox
349
Female threads in studding outlet got cross-threaded. Original threads are not salvageable.
It is a very large flange. Replacing is possible but only as a last resort. Repair would be preferred.
Does code have rules for how this can be repaired?
NBIC Part 3 has a section (S2.13.14.1) for repair of threaded openings, but I don't think this is applicable for blind-tapped flange bolt holes.
Would something like a heli-coil insert be allowed?
We've dealt with this in the past. Threaded out a larger diameter, then designed a threaded-both-sides insert. It has worked for 15+ years. Not sure if this is covered by any standard.
Generally speaking, if a thing is not prohibited, it is permitted.
Regards.
Mike
Diameter of the hole and material of the flange?
See ASME PCC-2 Repair of Pressure Equipment and Piping.
Thank you all kindly for the replies. ASME PCC-2 has an article specifically for this problem.
