compine static with frequency analysis thanks for your attention
fanis_greece
Student
Nov 12, 2023
hello there i am a student engineer from greece an i am working on an analysis for a wing ,my question is how can i apply an internal force on a part on my assemply and after that with that force applied to do a frequency analysis. I tried to create to step where i the step 1 i apply the force an in the step 2 i apply the frequency analysis but it seems that there is no difference if there is the force or not
thank you all ,with respect
Would be nice to know which software you are using.
It should work if you enable Nlgeom (geometric nonlinearity) in the first step.
