how to print on the screen or export the axial inertia moment of a model, in ANSYS Mechanical APDL
Dear fellow engineers,
I am using ANSYS Mechanical APDL 2023 R1 for a static analysis. I can setup the simulation However, I wonder how can I print the axial inertia moment Ixx (area moment of inertia), in relation to the center of mass on the screen, or export it to a text file, upon the solution.
Thank you,
Best regards,
Andrade Silva
RE: how to print on the screen or export the axial inertia moment of a model, in ANSYS Mechanical APDL
If you have areas defined in your model, then can use ASUM command to get the Ixx information and use /OUTPUT command before ASUM to redirect output to text file. Don't forget to issue /OPTPUT again without any argument to redirect the output to screen/standard output when you no longer want to redirect output to file.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
