Contact US
Recirculation Pump for Water Tank
I have posted about this system before, but not specifically the problem i am posting about now.
We have a small instant water heater that has a small water thank (1 litre) attached to it.
The water heater is has a volume of about 0.5 litres.
Its for a very specific application.
When we need to use the warm (not hot max 40C) from this system, we press a button that starts a pre-heat cycle where the water heater comes on and a small pump starts, and heats all the water in the water tank and the water heater to 40C.
There are temp sensors to cut the power off to the water heater when ready.
This is the schematic of our system that i have posted before when asking about where to position the flow sensor:
I very very nervous about choosing a pump that would be ok.
We were looking for something 12v, about 20 watts, as we had tested with this power level and it was adequate for our needs.
I was discussing with various suppliers in China and settled on this pump after lengthy discussions with them (they did pressure tests / temp tests for me).
This is a link to the full manual: Link
We got the delivery about a month ago, and it was working well in our test environment.
This week we got a new sample PCB and instead of the temperature maxing out at before 40C, it was going to about 45C. This is a bug that will be fixed.
The problem was that the pump developed a leak on one of the screw threads (see video): Link
I found it very difficult to source this part and it was the item that i was most worried about when sourcing.
I was able to find something suitable in the EU market to benchmark the specification.
I do not know if the issue here is the water pressure (max 4-bar) or the increase in temperature or that that the pump is just not suitable for our application (which i worry is the most probable).
I realised that I do not have the specific material the pump is made from in my file so I have asked for the information.
I should be able to limit the pre-heat temp to 35 C but i do not want to have a part that is prone to failure in the system.
Your insight is always appreciated.
RE: Recirculation Pump for Water Tank
The pump looks rather cheap and cheerful and made from some sort of ABS plastic?
Have you looked at 12V marine pumps or RV type hot water pumps. Usually you're better off with hoses and hose clips.
Something like this https://www.amazon.co.uk/Camplux-Water-Pressure-Ca...
Google 12V marine RV hot water pump. Dozens of pumps come up so maybe you looked for the wrong thing?
We do use a pump like that in another part of the system, but we do not need anything with that level of power.
the spec on the link you sent also ABS
I am not arguing that the pump may be too cheap.
We need (if it is possible) to find something that is around 20 watts, that has a smaller footprint than the diaphragm pumps
the diaphragm pump we use specifically says that you cannot connect it to mains pressure - which we need for our application
At that price point we will not be able to sell our system.
if its a show stopper then I need to find out.
I see similar pumps to the one i ordered used on solar circulation systems: https://www.ussolarpumps.com/catalog/solar-hot-wat...
Do you think these will have the same problems as what i ordered?
Why reinvent the wheel? There are plenty of cheap, small water heaters readily available, and they do not use unnecessary pumps. The heating element is in the bottom of the small (or large) tank and rely on natural convection. Who would even think to put the heater above the tank, with the controlling temperature sensor far from the heater. So many things could go wrong.
https://www.vevor.com/s/water-heater-tank
You may be able to utilize convection to achieve your goal without a pump. Install the heater below the water tank. Hot water should return to the top of the tank, cold water flows from the bottom of the tank into the heater inlet.
This is a small part of a larger system that combines the water heater with a heat recovery system.
Most of it is working perfectly
We only heat the water to 40C so. Cannot keep it perminantly warm due to legionella.
I had thought about convection but it will not be quick enough.
I need to heat all the water in 1-2 min (depending on how cold it is)
Before we had this leak, we were very happy with the performance - but now I need to find a small pump that is reasonably priced that does what we need.
In a different part of the system we already use this pump http://www.seaflo.com/en-us/product/detail/609.htm... which I pay $28 ex-china
But you can't connect it to mains pressure and it's much too powerful/physically big for the recirculation.
I think that the type of pump I bought can work for what I need it for, but I need to know how to source the right one. Right material for the temp & pressure.
If you need to pump to withstand mains pressure, ~70psi, go with a diaphragm pump. They have pressure ratings up to 100 psi. The next challenge is selecting hoses that will be durable. At 40C you're within the limits that nitrile rubber wetted parts will tolerate in water though chlorine may have some interaction.
https://www.amazon.com/Seaflo-100PSI-Self-priming-...
A pump will not cause the water to heat any faster. That is determined by your heater power. You complain of cost sensitivity and insist on an unnecessary pump?
I do disagree with this statement. Flow rate increase the efficiency of a heat exchanger due to thinner boundary layers and turbulence. We don't have enough information to quantify the effect.
But, OP has fluid in two separate chambers so there does need to be some exchange of fluid between the two.
I do believe OP is underestimating the effects of natural circulation. I've operated marine boilers that were able to naturally circulate enough to evaporate 110,000 lbs per hour of water using natural circulation.
"I do not know if the issue here is the water pressure (max 4-bar) or the increase in temperature"
I have identified your problem:
"I was discussing with various suppliers in China"
You're welcome.
Good luck.
I know this isn't the question, but have you not thought about a thermostatic mixer valve instead so you can keep your water tank at 60C to avoid legionnaires and forget about this pump? Then insulate the heater tank and just keep it hot?
You issue is probably that these cheap pumps are simply not made to have up to 4 bar / 60psi on them constantly and some of them will leak.
Some will be rated for higher, but maybe not on the inlet / suction side which is where your leak is happening I think.
Those rated for higher pressures will cost more.
the roadmap does include the setup you suggest - but this will be for larger versions of our system.
I have contacted different suppliers and I should be given a reference from a company in the UK that is using a similar type of pump from http://www.topsflo.com/brushless-dc-pump/tl-b10-br...
the UK company has a similar use case to us apparently - i will see what they say.
It looks the same thing tbh as you have now.
Note Max head 5m (0.5 bar). No static pressure rating.
I don't think any of these ABS type plastic bodies are going to be able to cope with mains water pressure up to 4 bar. They are just not strong enough. IMHO
At your temperature, glasses fill is going to matter for strength more than the plastic resin.
"I do disagree with this statement. Flow rate increase the efficiency of a heat exchanger due to thinner boundary layers and turbulence. We don't have enough information to quantify the effect".
We are talking about electric resistance heating. Flow rate has no effect on heat transfer efficiency, which will be 100 percent.
And having two separate chamber is the first fundamental mistake. Both "chambers" can simply be one wide spot in the pipe.
Without flow only the water in the heater will get warm, at least over short periods.
Perhaps the word "effective" would cause less offense?
Have you looked at peristaltic pumps?
It needs an expansion chamber. Typical water heaters allow expansion back into the supply line but that path is blocked off here. There should also be a pressure relief valve with the check valves.
the diagram is a simplification of the system. the water tank and water heater are not directly connected. There are other components in between.
the pump circulates the water everywhere in the system
Convection will not circulate the water quickly enough for our needs.
If it were possible to just have a larger tank where the heating element was - i would have done that - removing the problem is always better than fixing the problem.
This company did send me this test report for pressure testing. Like you i questioned why they did not state the static pressure on the spec sheet for the product: https://jackbensonhotmail-my.sharepoint.com/:b:/g/...
I will research peristaltic pumps
thank-you 3DDave.
I wonder if the increase in pressure in the system could have caused the pumps failure.
In standby, the water in the system will be at whatever the network water temperature is (between 7-22 C depending on the time of year) [There will be some warming based on room temperature depending on how long the system is left in standby mode].
The system has a preheat mode that is entered into while the tap is closed.
This means that the approx. 3 litres of water in the system was heated to the target temp which was approx. 43C at the time of the pumps failure.
There would have been a rise in pressure in the closed system as the temperate would have risen by approx. 20 C.
As it has been pointed out, there is a one way valve preventing some of the pressure being relived into the pipework.
I would like to work out what the pressure rise would have been. https://www.eng-tips.com/faqs.cfm?fid=1339
On Monday we will test this will a pressure gauge.
It's about 2 bar per C.
Relief of even a few drops in that amount of water would relieve the pressure, but yes, you need to install a pressure relief valve or an expanding tank or both rather than have the weakest part of the system do it for you.
I think 3DDave is right about needing a small expansion vessel. With a shut-in section subject to temperature changes, you ought to have a relief valve somewhere downstream of the inlet one-way valve as well.
Trying to calculate the pressure rise is a fool's errand. That will depend too much on the elasticity of the pipework and other components, with compressibility of the water just adding to the confusion. Work out the increase in volume and use that to size an expansion vessel. A 10 bar rated, 2 litre expansion vessel suitable for potable water should be available off the shelf from your local plumbing supplier for around 30 Euros. Much smaller (0.16 litre) units are also available at broadly similar prices.
I saw a broadly similar hot water system the other day - one where somebody has helpfully included two ridiculously large, 207 bar working pressure hydraulic accumulators into the circuit. I feel the overkill solution there may be a sign of how frustrated they were getting beforehand.
A.
(Addon: I was still typing when LittleInch posted)
LittleInch Thank-you
zeusfaber - i agree trying to work out the exact number is pointless. I was more trying to work out if this could be the cause of the pumps failure.
Whatever the outcome we will add a pressure release valve
Most of the pipework is EPDM flexible hoses that will have a level of flexibility.
I will measure the pressure rise on Monday during preheating.
I will look into a small expansion vessel
Thank-you
I went though the log files saved from our test environment and found that at the point that the pump failed, the temperature in the system had risen from 21C to 56C - a 35C temp rise.
There was a bug in the test firmware in the PCB that did not prevent the overheating.
The system has a solenoid valve that I can programmatically open momentarily to release pressure from the system as the temperature rises, although a pressure release valve is the safest options as it does not rely on the PCB.
I am looking at options to manage the expansion.
I have seen these textile braided hoses that appear to be designed too expand as water heats up.
This article gives a rate of expansion of water is 1.000208 per 1C rise in water above 4C
In the error state the system was in, with a 35C temp rise, if the article and my maths are correct, the expansion would have been 1.007305801.
For 3 litres of water this would mean 21 ml.
Can someone confirm if this this correct?
In normal operation, the max temp rise should be 7C to 35C = 28C
thank-you for everyone's help
C Temp Rise Expansion / C Total Expansion
1 1.000208 1.000208
2 1.000208 1.000416043
3 1.000208 1.00062413
4 1.000208 1.00083226
5 1.000208 1.001040433
6 1.000208 1.001248649
7 1.000208 1.001456909
8 1.000208 1.001665212
9 1.000208 1.001873558
10 1.000208 1.002081948
11 1.000208 1.002290381
12 1.000208 1.002498857
13 1.000208 1.002707377
14 1.000208 1.00291594
15 1.000208 1.003124547
16 1.000208 1.003333197
17 1.000208 1.00354189
18 1.000208 1.003750627
19 1.000208 1.003959407
20 1.000208 1.00416823
21 1.000208 1.004377097
22 1.000208 1.004586008
23 1.000208 1.004794962
24 1.000208 1.005003959
25 1.000208 1.005213
26 1.000208 1.005422084
27 1.000208 1.005631212
28 1.000208 1.005840383
29 1.000208 1.006049598
30 1.000208 1.006258856
31 1.000208 1.006468158
32 1.000208 1.006677504
33 1.000208 1.006886893
34 1.000208 1.007096325
35 1.000208 1.007305801
36 1.000208 1.007515321
37 1.000208 1.007724884
38 1.000208 1.007934491
39 1.000208 1.008144141
40 1.000208 1.008353835
41 1.000208 1.008563573
42 1.000208 1.008773354
43 1.000208 1.008983179
44 1.000208 1.009193047
45 1.000208 1.009402959
46 1.000208 1.009612915
47 1.000208 1.009822915
48 1.000208 1.010032958
49 1.000208 1.010243045
50 1.000208 1.010453175
51 1.000208 1.010663349
52 1.000208 1.010873567
53 1.000208 1.011083829
54 1.000208 1.011294135
55 1.000208 1.011504484
56 1.000208 1.011714877
57 1.000208 1.011925313
58 1.000208 1.012135794
59 1.000208 1.012346318
60 1.000208 1.012556886
61 1.000208 1.012767498
62 1.000208 1.012978154
63 1.000208 1.013188853
64 1.000208 1.013399596
65 1.000208 1.013610383
66 1.000208 1.013821214
67 1.000208 1.014032089
68 1.000208 1.014243008
69 1.000208 1.01445397
70 1.000208 1.014664977
71 1.000208 1.014876027
72 1.000208 1.015087121
73 1.000208 1.01529826
74 1.000208 1.015509442
75 1.000208 1.015720668
76 1.000208 1.015931937
Seems about right
The volume is small but as the Bulk modulus is very large the pressure rise can be significant.
The pipes may well be limiting the pressure rise as they expand, but it will be higher than your static pressure and providing an expansion vessel or relief valve is required. Problem with a relief valve is that it now needs a drain....
I understand that the increase in pressure would be significant. I am not trying to argue it.
I was wondering if by adding a specific type of flexible hose that is designed to expand when the water expands due to being heated it could be a solution (but you are right - the pressure would rise above the static pressure level).
In the circuit, there is a normally closed solenoid valve that connects directly to the drain.
It would be possible to open it momentarily [every few degree temperature rise] to relieve the pressure.
We will do some testing to see how much the pressure rises per degree and go from there.
Having both is most likely to lead to trouble-free operation.
The expansion vessel will prevent the relief from lifting all the time and save you wondering when it will eventually fail to reseat.
The Relief will save your pump when the expansion vessel loses all its gas charge.
A.
Yes
We ran the test this morning.
We increased the temp in the closed system from 20 C to 40 C.
There was a maximum 0.2 bar rise in pressure.
my best guess is that the flexible pipes in our system absorbed the expansion.
This is a Video of the test. At 1 min 37 sec we open the tap and the pressure drops to 2.4 bar.
The only unusual factor we have now at the time of the pump failure was that the water temperature increased to 56C instead of the usual maximum of 40C.
thank-you to everyone who has contributed to this thread.
we ran the pressure test again, and it hit 9-bar [an increase of 6-bar]:
we must have not set up the pressure gauges properly in the first test that did not show a pressure rise
An expansion vessel & release valve should solve this issue as recommended.
The water in the system was about 21 C before the heating element as turned on.
This is the video of the test.
When the video starts, the pressure is already 3.7 bar from the 3-bar that was the pressure before heating started.
We then warm the water to 43 C
The pressure peaks at 9-bar at around 3 min 18 seconds
The pressure then drops off (the temp of the water in the system is maintained but not increased.
After 16 minutes, the pressure has dropped back to 6.4 bar
The tap remained closed thoguhtout.
I would not have found this without your help.
It is very much appreciated.
Lots of reasons why the previous test was different. Even a small amount of air somewhere would make a difference or any leakage past any of the valves.
Expansion tank will make life better for sure.
Hello everyone,
thanks for your help with this post.
the mini expansion vessel has solved the issue
We are also installing a pressure release valve.
I would prefer to just install the pressure release valve and not the pressure vessel.
is it advisable?
https://www.youtube.com/watch?app=desktop&v=uW...
In France i see a lot of instant water heaters that only have the pressure release valve to manage excess pressure in the system:
Can i use a standard 5 bar pressure release valve that i can easily plumb into my system:
my system has access to the waste pipes.
thank-you
reading this again I think you already have the answers.
apart from 15th Oct "Problem with a relief valve is that it now needs a drain...." compared to today "my system has access to the waste pipes."
as Zuesfaber says "The expansion vessel will prevent the relief from lifting all the time and save you wondering when it will eventually fail to reseat."
These little relief valves are not intended to work regularly and after a few operations will not reseat and drip continuously or just fail. Also your set point needs to be at least 25% higher than your highest normal operating pressure to prevent weeping.
Probably more so your pressure will vary a lot more than using an expansion vessel.
Not to mention finally "the mini expansion vessel has solved the issue" If it ain't broke don't fix it comes to mind....
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
