Pipe description
xnabrar
28
Hy all,
I am stuck in the below description and want to understand below basic description.
PIPE, CS API 5L-X65M-PSL2, SAW, STRT SM, BE,
pipe: pipe
cs: carbon steel
API 5L-X65M: STANDER WITH GARDE
SAW: WELDING TYPE
BE : BEVEL END
STRT SM: What is the exact meaning of this?
thanks
Straight seam?
As opposed to spiral wound?
I've had a good look through API 5L and can't find any such abbreviations.
I talk with designer,this is a straight seam.
Good - that one's sorted.
A bit odd as that's what you would normally expect...
I'm not sure I ever realised what the "L" stood for (L= Longitudinal, H = Helical or spiral)...
