FEMAP API FOR DOCUMENTING IMAGES
Xprivate
Aerospace
May 26, 2023
55
Hi All, is there an API that generates a report with images from current view for all the outputs files in the result. Lets say i already have a contour plot being displayed , is there an API that copy paste the contour for different results into a single file ? thanks in advance
"print" ? to pdf, and use pdfsam to merge together ?
Where do you want the image to be copied to? Word, PowerPoint, Excel, some other program...?
I would try using App.feFilePictureCopy2(....) or App.feFilePictureSave2(....) but then pasting or importing probably depends on where you want it to go.
