Unable to Import a PDF into a DWG/DXF File in Draftsight 2020 Enterprise
PLCAlligator
1
Hello Friends,
I am trying to find a way to import a PDF to a DWG/DXF from Draftsight 2020 Enterprise. There is no option to do this in DS on the import tab, only options to import DGN, SAT, DELMIA XML, 3DCC, HomeByMe, SVG.
The attached product feature matrix shows DS2020 Enterprise should be able to do this (with a 3rd Party plugin). Is this a free plug-in and how do I install it? Are there other, simpler ways to convert pdf to dwg/dxf, and where can I do that?
I also use Solidworks Electrical 2020, if there is a way to do that in there.
Thank you.
 https://files.engineering.com/getfile.aspx?folder=206b83e2-388d-4e06-a105-3a05ba2bf886&file=DraftSight_Feature_Matrix_2020.pdf
