change active cell in excel
William Heath
change active cell in excel; i know I can press Cntrl G and enter the cell to go to. To make it easier, I would like a button which could be clicked and have the spreadsheet automatically move to a different cell
Any ideas would be appreciated
Stick the command in a macro, create a button, and assign the macro to the button
This is an example macro that I used for a couple of things
Code:
Sub Macro2()
    Range("A1000000").Select
    Selection.End(xlUp).Select
    EndDate = ActiveCell.Value
    Sheets("BP Full Chart").Select
    ActiveChart.Axes(xlCategory).MaximumScale = EndDate + 3
    Sheets("BP Chart").Select
    ActiveChart.Axes(xlCategory).MaximumScale = EndDate + 0.25
    ActiveChart.Axes(xlCategory).MinimumScale = Round(EndDate) - 10
    ActiveWorkbook.Save
End Sub
TTFN (ta ta for now)
William,
There are so many places to go and so little time!
You need to look at Named Ranges. If you have a location in mind, it ought to have been given a name and then by accessing the Name Box, you will be able to select ANY of your Named Ranges.
I would, however, respectfully take exception to IRstuff. I always avoid using Select and Activate with the exception of leaving a Procedure, where you might want the display/activecell to be a specific workbook, worksheet, cell.
Select and Activate are commands that slow down your process. And each DOT level in a statement takes time to process, which is a reason to use With...End With.
Code:
Sub Macro2()
'We're not sure what worksheet we are on to get the EndDate. Would be better to identify
    EndDate = Range("A1000000").End(xlUp).Value
'These worksheets do NOT need to be Activated in order to access their data
    Sheets("BP Full Chart").Axes(xlCategory).MaximumScale = EndDate + 3
    With Sheets("BP Chart")
        With .Axes(xlCategory)
        End With
    End With
'I'm assuming that this procedure is located in the workbook that is being saved
    ThisWorkbook.Save
End Sub
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
I found that I could do what I wanted using Hyperlinks. Thanks
