High Grip Rubber?
Tobias_CS
NO
I need a material where, imagine when you press your finger with force on the surface and try to glide your finger across the surface, your finger is stuck in place (when applying pressure). Once you release the pressure, you can easily glide your finger across the surface.
Any help to locate a product / item like this is greatly appreciated!
Sorry, no idea.
But I did a few quick G searches, and the search string with the most promising responses was:
rubber with high surface friction characteristics
TygerDawg
Blue Technik LLC
Manufacturing Engineering Consulting
Have you looked into any of the butyl rubbers?
