Amada FO-3015 - Alarm 2154 - sensing alarm
Richardwen
CA
Hello
I am having a problem with my 7.5“ lense I am getting a 2154 sensing alarm and it will cut about an inch and then it will start sensing and moves up and alarms out. When I turn the shutter key off it it will trace the outline as soon as I turn it on it cuts an inch and alarms out.
I switched to a 5“ lense to see if it will cut thinner material we ran a test cut on same 14GA and it cuts beautiful.
Any ideas what may cause this?
Thank you!
After it cuts an inch or so, is the nozzle and cone super hot?
