What is the general practice of gro 3
dfdt
AU
What is the general practice of grounding the sheath of control cables especially in HV substation/ switch yard. Do you ground the sheath or screen of the cable only at one end or at both the sends of the control cable?
One end.
Ohm's law
Not just a good idea;
It's the LAW!
Agreed; one end ONLY so as to preclude circulating currents.
This thread ONLY to be used going forward; I have asked for your double post in EP&T&D forum be deleted, as double posting is forbidden.
CR
In HV substations, control cable sheaths are typically grounded at one end, known as single-point grounding. This minimizes circulating currents and provides a reference point for the control system. Double-point grounding may be used in specific cases, but adherence to manufacturer recommendations and system design considerations is crucial.
