Good morning,
I have a installation which needs Nitrogen. I am using Nitrogen gas cylinders. The issue is that I have simulated the expansion proccess in a very simple way:
- Inlet line with fixed flow and pressure (around 200 bar)
- Pressure reducer valve
- Outlet line. Same flow (mass) and pressure (around 2,3 bar)
The problem is that depending on the thermodinamic model, temperature after the pressure reduction is very low or not so low. Any recommendation of which model I have to use?
Apart from that, Some years ago I used these cylinders to feed Nitrogen to a vessel for blanketing and I cannot remember any issue with temperature, so I am doubting if I am simulating it properly.
