ASME Section 2 part D Extrapolation
I've done the design study for standard temperature. My part has a max psi of 3000 at standard temp. using a material with an allowable stress of 24ksi. Can i extrapolate the max pressure to 300 psi using the listed allowable stress of 21.2? so 21.2/24*3000 giving a max pressure of 2650 psi. I know there is a linear relationship but is this form of extrapolation allowed or am i required to run the study at the higher temperature.
RE: ASME Section 2 part D Extrapolation
Mike
Calculation: 21.2/24*2220 = 1960 which matches the 1965 in the spec. The same is for the class 1500 range as well 21.2/24*3705 = 3273 which matches the 3270 in the spec.
So if my valve has a maximum operating pressure of 3000 psi at standard temp then 21.2/24*3000 = 2650 psi maximum operating pressure at 300F, where 24ksi = allowable stress at standard temp and 21.2 = allowable stress at 300F
-Christine
