Howdy all,
I was looking for a set of switches, 813387-3/-4/-5 and they each have a long list of PMA parts. Removing duplicates there are 23 separate PMA parts that are common to all three of these parts. These 23 PMA parts are approved as alternates for multiple OEM parts. In fact there are 25 different OEM parts that these PMA parts are allowed alternates for. 19 of the PMA parts have the same list of 23 OEM Parts they replace.
So I expect these switches are all identical, with perhaps the only difference being wire length, but they list a different P/N for each top level part number they go on. Could I use this to justify using an alternate OEM part number to use an equivalent, perhaps identical switch from a different part?
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
-Kirby
Kirby Wilkerson
