Contact US
Pump clearances
Pump clearances
Pump clearances
In vertical multi stage condensate pump drawing, guide bearing has fit 120H8/f9. When I calculate it is clearance fit with
Min clearance: .036mm
Max clearance: 0.177mm
Where as in Pump instruction book of same vendor, nomianal clearances for guide bearing are as under
Min clearance : 0.15mm
Max clearance: 0.4mm
Kindly educate me whether my calculations are correct and if yes, then why two values are different?
If my calculations are wrong then what is mistake?
Daren!
RE: Pump clearances
Maybe the vendor doesn't known what they are doing.
As usual the first port of call should be the vendor - who else is better qualified to advise on their own product?
RE: Pump clearances
Company has abandoned production.
Daren!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
