abaqus or solidworks
engines manyama
1
how do i find the shear center of a channel section using abaqus or solid works? Do i need the theoratical value ?
In Abaqus, you can use the *BEAM SECTION GENERATE procedure to obtain the cross-section properties including shear center.
cell is not partitioned completely. unable to do partition. sketch included. call partition required for hex. mesh
