H choudhary
what constraint can I apply between the a 1D beam element (RED) which is M3 bolt and a hole in 3D bracket (orange)? there a RP in front the bracket where the load will be applied and the RP will be coupled with the M3 bolts. I am trying to monitor the stress on a M5 bolt which is further back in the assembly. I must use a beam element here as I have to fulfill the assignment requirements.
thanks for any suggestions.
