jerseyshore
- May 14, 2015
- 932
Went to a building today with some classic late 60s/early 70s architecture, the highlight being these precast panels. They are not only the exterior facade, but also in half of the interior side of the building too. Man the 60s must've been weird.
Anyway, on two corners the panels have started to pull away from the backup. The building appears to be mainly block walls, but Photos 2 & 3 are at a double cantilever overhang, so there might not be block there.
Any thoughts on a simple repair here? I was thinking some masonry anchors, Helifix or Simpson or similar anchors (assuming there is block behind). I don't do a ton of precast panel work, so not overly familiar with the repairs. Appreciate any thoughts.
