Contact US
High temperature of Plan 23 Cooling water return line to heat exchanger during recirculation
We have 4 stage boiler feed water pump and it uses plan 23 for mechanical Seal. After necessary maintenance, pump was taken on recirculation line. I observed the temperature of return water to heat exchanger ( heat exchanger used in plan 23 for mechanical Seal) was higher then adjoining running Boiler Feed Water Pumps same return line. Vibration parameters are normal. My question is
1. Is it normal behaviour ? If so why ?
2. If it is not normal then what can be reason?
Daren!
RE: High temperature of Plan 23 Cooling water return line to heat exchanger during recirculation
There is noting abnormal when a HP BFW pump shows higher temp on recycle line when in total recycle - it is the same as heating up the BFW by the same power as the pump motor.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
