Riveted chassis and FEA
How would one go about modeling riveted joints of a riveted aluminium sheet monocoque on Solidwork FEA ( or another ) ?? should i use bolts, or simplify by juat surface contact and clamping force ?
If yes how do i calculate clamping fprce of a rivet ?
Thank you
RE: Riveted chassis and FEA
That depends what your FEA model is for. If you are doing fatigue analysis then you either need a much more complex model of the rivet, or else you find the local stresses around a simpler model and then use manual methods.
Cheers
Greg Locock
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
