G Loads for Half Symmetric FE Model
struclearner
122
G (Gravity/Acceleration) load, for Half FE Model, utilizing the symmetry of the structure, will be the same as for full model, because the g loads produce inertia force calculated from F = ma, on the structure.
I appreciate, your inputs and valuable suggestions, if this is not the case.
Yes, when using symmetry you can still apply gravity load normally. It will be based on the mass of the modeled portion of the structure.
Check your assumptions by building a very simple model as a full and symmetric model then check that the results are identical. if not then you have more to learn. In my experience exploiting symmetry often leads to tears (more generally BCs are the usual issue with FEA models, not the meshing bit).
Cheers
Greg Locock
a 1/2 symmetric model requires symmetric loads (ie you can't model rolling manoeuvres, only pitch manoeuvres).
Struclearner.[ ] What you assert is generally true, but does not apply to any elements that lie entirely within the symmetry plane.[ ] Special treatment is required for these.
Engineering mathematician/analyst.[ ] See my profile for more details.
