Hi everyone,
We are having a vendor fabricating a 48" dia. vessel for us.
We have an issue with a manhole for inspection purposes.
According to ASME VIII UG-46; all vessels greater than 36" in diameter shall have a manhole, except when the shape of the vessel or use of a manhole is impractical in which case 2 handholes are needed with an equivalent area for each at 4" x 6".
The vendor is telling us a manhole is impractical thus they are using N3 and N4 nozzles (6" dia. each)as shown in the attached picture as the inspection holes.
The reason why it's "impractical" is not clear but I thought I would ask this quick question here to see if it's even worth looking into this. Apologies for the poor photo resolution -- i'm having trouble uploading a clearer image.
