Abaqus - Get minimum bounding rectangle/box from closed sketch regions
DKEngineer
Student
Apr 3, 2023
20
Does anyone know a method where it is possible to get a minimum bounding rectangle/box from a closed region in sketch. I have to collect geometrical parameters of closed irregular regions, and therefore the minimum bounding box width and length are important.
If not possible in sketch module, then I guess I will have to work in the mesh module. Using a partition line for the closed region to control mesh nodes.
The figure shows an example of an irregular closed region with a minimum bounding box.
I just found python code from Github calculating the minimum boundary box using provided points. So if not possible in sketch module, I will implement the algorithm to the node points.
You don't specify whether you are trying to minimise the rectangle's area or its perimeter, and I am not 1000% sure that both answers will be identical in all cases.
Engineering mathematician/analyst.[ ] See my profile for more details.
Thats right. Actually, both methods would be relevant.
The getBoundingBox() method in Abaqus Python scripting might be useful in this case. You can find its description in the documentation.
