ANE91
- Mar 31, 2023
- 392
First time poster
We, a private consultant, performed a load survey for an owner on their large warehouse building. There were precipitating load events prompting our survey. In one area, we discovered that the 30K7 roof joists supported four new 6-inch SCH10 fire suppression lines. The lines are attached not-quite-concentrically between panel points. New Millenium says the joists don't calc out (but will not provide their calcs or models). I am tasked with modeling each joist to include the four "new" point loads. I have access to RISA-3D and VisualAnalysis.
How do I model this joist? I do not know the precise double-angle section comprising the chords nor the crimped web channel properties. I looked into "Virtual Joists," but they seemed intended for initial design prior to requesting SJI sizes from the manufacturer. This is just a joist and not a joist girder. I do not have shop drawings. The as-builts from the city do not contain joist details. In the past, I have recreated such joists in a model when provided the as-built joist detail containing specific dimensions, section properties, joint assumptions, etc.
SJI provides strengthening details and calc sheets. In addition to any flexural strengthening (e.g., with tensile rod reinforcement, etc.), I anticipate needing struts between the point loads and the bottom panel points. I cannot know exactly where and how to reinforce the joist without first modeling it precisely to see where the overloads (if any) are.
There are no alternatives. The lines cannot be moved. I do not want to specify excessive supplemental steel "hoping" it works without first calcing it out.
