Creating Dimension on Sketch then Extrude
lgchan
MY
I have done a simple macro where I insert the parameter needed for the cuboid, then it will perform the cuboid out.
But, I would like to add a few lines of coding in my macro which can have dimension on the sketch after I sketch the square/rectangle, then proceed with extruding function.
If there are other macros that have problems, please help me amend them.
Thank you very much.
 https://files.engineering.com/getfile.aspx?folder=15292721-d8d3-483e-9c60-aa22a44f7f06&file=Rectangle_extrude.docx
