associative number of planes 1
moog3
Marine/Ocean
Nov 29, 2022
68
anyone got any tips for setting up Datum Planes with an associative number of copies
I can't use an expression, only a number, once the planes are created, I can't add more in the same feature.
maybe try with pattern feature?
Best regards
MANok
NX2006
Tc14
There were times when I had several parallel datum planes that I related to sketch curves (lines)
so it could easily be seen what the dimension to each datum plane was.
If I have time I will post a sample NX file.
Jerry J.
UGV5-NX1899
Create a single plane and then use Pattern Feature to create the copies.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
As mentioned above there are times when I like relating my datum planes to a sketch line so the dimension to them are clearer.
The sketch and its dimensioning can be created to make the datums equally spaced or not.
I attached a simple file to demonstrate it.
Jerry J.
UGV5-NX1899
 https://files.engineering.com/getfile.aspx?folder=9941fe70-6e1f-43ae-88f6-58b44a160491&file=planes.prt
thanks guys, I think pattern feature suits me best, for this time.
