Sieve Analysis and Hydrometer
Shakta
Geotechnical
As Sieve analysis with hydrometer test ASTM D422 was replaced by D6913 (sieve analysis) and D7928 (hydrometer), how do you present the result. Do you combine both result and present in one grain size distribution plot, or use two separate plots for sieve analysis and hydrometer part. Is there any direction for combining them? Thanks!
If you are doing and ASTM show everything required in the ASTM reporting section, if you can do both on one sheet then do it.
