API 610 Table 14 Inspection Class II basis
JRotary
SG
Hi Colleagues,
Good day!
Just would like to check what is the reference Pressure data/value does the “>80% MAWP” is being referenced to require Class II inspection?
Not sure if it is based on the Discharge Pressure or the Rated head/pressure or any other value.
Thank you in advance!
