Contact US
Tube to Tube Sheet Mock up (Performance Qualification) QW-193.2
Back Ground:
A welder welded 10 tubes in which one tube rejected in visual test and two in macro examination but other 7 tubes accepted in visual, PT and macro examination.
Question:
Is welder qualified as per QW-193.2 " a minimum 05 tubes are required for qualification".
Reference attached.
Fahad
RE: Tube to Tube Sheet Mock up (Performance Qualification) QW-193.2
Why did the welder weld 10 tubes instead of the required 5 tubes ?
You have 5 x acceptable so theoretically the welder has passed.
However, the code provides minimum requirements - it is up to you as the representative of the employer to decide on acceptability of the welder.
3 x DNC from 10 x welds - a 30% failure rate. Not acceptable.
This is only my opinion but if I was in your position I would have the welder weld a further 5 x tubes and all 5 must pass.
Agree with DekDee. Make sure that the welder sees the welds that did not pass and explain to him/her why the welds did not pass.
I suggest further training or practice and then new test.
Dear All,
Thanks for your comments,
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
