Leak of Stainless steel plug, Material defect??
Hello everyone,
Problem: The new plug of the air cooler heat exchanger made from stainless steel leaked during the leak test. The plug was new and never used. The defective plug was sent to be tested using PT and PAUT and it found the defect at the center and along the entire length of the plug (that's why it leaked during the leak test). I'm confident that this defect is not due to the machine processing used to create the plug.
The plug was sent back to the supplier for the RCA but finally, they didn't respond to the inquiries anymore. So, I'm here to get your thoughts on the possible root cause of the plug defect. Is it an inherent discontinuity or defect from the original melting and solidification of the metal?
Thanks for any help.
RE: Leak of Stainless steel plug, Material defect??
This left shrinkage defects (pipe) down the centerline.
I have seen this with plugs, machined elbows, and valve bodies.
This is why expensive fittings are made from extruded or forged stock.
They don't leak.
What is the ASTM/ASME material standard that the plug was supposed to be manufactured to ?
MJCronin
Sr. Process Engineer
The material supplier is in the USA.
Material spec. in PO is SA-479 316L
Can you see the porosity using penetrant? (liquid fluorescent maybe)
What did the supplier say? The parts are obviously defective.
