Import and Export Plot Styles
It's not for autoCAD, but for Bricscad, a similar program. Does anyone know how to import and export plot files. I'm just rebuilding my computer system and need to transfer some plotfiles to the new machine.
Thanks, Dik
Thanks, Dik
RE: Import and Export Plot Styles
I just copied an old .pc3 file into my Plotter Configuration Path while BricsCad was open and it showed up in the plot dialog...
PC3 files are saved in the Plotconfig subfolder of your Roamable root folder.
It is unlikely Bricscad is so sophisticated that it keeps some hidden internalized list - but you could search all the Roamable file contents for the names of the configs that are in the list to see if a file contains that list.
