Is there a way to copy driven dimension values?
jassco
I need to copy some driven dimension values in a sketch from Solidworks to another application. I am surprised that I can't copy and paste it. I had to retype them manually. Is there a workaround? Thanks!
Best regards,
Alex
You can use a macro to export the selected dimension to a text/excel file and use from there.
Deepak Gupta
SOLIDWORKS Champion and Expert
SW 2022 SP0.0, 2021 SP5.1 and 2020 SP5.0
Boxer's SOLIDWORKS Blog
Hi, Deepak:
Could you please show me a statement of this macro? I need to send dimensions with decimal of 6 digits to an existing macro to curve-fitting in Solidworks.
Best regards,
Alex
Hmmm… can't reach this page
I just noticed that I can copy linear and angular dimensions using Ctrl C and V. But I have to set numbers of decimals first before I do that.
Best regards,
Alex
