Joshmead923
Student
- Jan 14, 2023
- 1
My name is Josh, I work in the theatre industry and have an interest in automation. I recently set myself the task of creating a scissor lift from scratch. However, having never touched Mechanical Engineering I fear I’m well and truly out of my depth!
I’m struggling to find the correct formulas for working out the force needed to active the scissor lift at different points, e.g the bottom middle or top. I’m hoping you could point me in the correct direction, please.
I have found the formula:
F=(W+WA/2) / Tan (A)
Where as:
W = Weight of load
WA = Weight of arm
A= Angles of arms to the ground
However I do not understand where the force calculated should be applied on the scissor lift arm?
Additionally, I have found the formula:
The sum of the movement of A = FA X (L/2 x Cos Alpha) - ( F x (L X Cos Alpha)
Where as:
FA = Force on actuator
L= length of leaver
Alpha = angle of leaver.
I believe this formula gives me the force on an actuator vertical to a leaver, unfortunately I don’t know how to change this so the actuator doesn’t have to be vertical.
I found a few papers online but, alas, as a novice I don’t understand them.
I would greatly appreciate any help in finding the correct formulas.
I’m enjoying learning about this new subject and would love to know what books or reference material you would recommend for future projects.
I appreciate you taking the time to read this email, any guidance would be greatly appreciated.
Where as:
W = Weight of load
WA = Weight of arm
Where as:
L= length of leaver
