ETABS Negative Wind Pressure Coefficient
EngrJS1
PH
I am modifying the wind load parameters in ETABS based on ASCE 07-16 which requires inputting windward and leeward coefficient (wind exposure pressure coefficients). Based on ASCE 07-16, the leeward coefficient is -0.5. In ETABS, Do I need to input 0.5 with the negative sign?
 https://files.engineering.com/getfile.aspx?folder=ff6c6db4-472d-4fb2-83b9-2c5d400ce68e&file=Screen_Shot_2023-01-09_at_1.15.33_PM.png
